Printing with colorFabb XT Clear
JTBrown
Posted (edited) · Printing with colorFabb XT Clear
Please can you help?...I'm using colorfabb Xt Clear and I want as transparent a print as possible. At the moment the layers are being printed in opposite direction to the previous one witch makes the print murky, I've realised that I need each layer needs to be printed the same way. Any ideas?
Edited by JTBrown
    Thanks but the main part of the question was can I adjust Cura to print the same directions, shell and infill, on each layer?
    Edited by JTBrown
    Posted · Printing with colorFabb XT Clear
    Indeed, and i checked Cura for that.
    You could try "Infill line direction" and see whats in the preview. But imho the distribution of the material is by crossing lines is neccesary. Maybe 0/90/180/270 degrees will work.
