Thanks for your insight MM. The instructions in the wiki are dodgy in my opinion, and don't address the different software options.
To be more clear about my measurement, basically I pulled the bowden tube from the fitting at the extruder mechanism so the filament could come right out the top. I unlocked the drive mechanism and pulled the filament thru until I could close it on 'virgin' material. I closed the drive clamp and checked for 'proper' bolt tension. Wrapped a piece of tape around the filament flush with the push lock fitting. Ran the gcode to extrude 100mm. Then measured the displacement of the tape with dial calipers.
I will give 1200 a try as the constant. It just seems way out of line from the norm. By the way, I did check that the bolt is clean before testing.
Matt
15
13
12
7
Popular Days
Mar 2
21
Mar 6
11
Mar 7
7
Mar 4
7
ddurant 15 posts
mm_build 13 posts
joergen 12 posts
mastory 7 posts
Popular Days
Mar 2 2012
Mar 6 2012
Mar 7 2012
Mar 4 2012
mm_build 1
I've been meaning to get around to this for a while, so thanks for giving me an opportunity.![:D](//content.invisioncic.com/ultimake/emoticons/5a33abe7dfbbe_1f600copy.png)
I repeated this test several times each at speeds of 40, 75, and 200. All the results were too close for me to notice any difference. I measured ~93mm of extrusion in virgin filament, and ~94.5mm in previously extruded filament. (with an E value of 865.888)
My method was to disassemble the hot end, mark the filament with a razor knife flush to the bottom of the bowden tube, extrude 100mm, repeat. I took the filament afterwards and put it flat against a straight millimetre ruler. I would have tried your method too but I couldn't really follow from your description what you were doing. If your numbers are that far off I suspect it's something to do with how you are measuring, but I could be wrong. There is a range of extrusion rates that your print will still look OK with, even if it is not ideal.
According to my calculations I should be using 931 as my E value, which is closer to the value for the old hobbed (which I don't know off hand).
If you are confident in your method of testing, then I would suggest trying out the number it gives you and see how your prints look. I will be doing some more testing myself, in fact I will be putting my new values in and extruding 1000mm to see where that gets me.
The code I used to extrude is below
