Hi @MarissaP, thanks for the file. I recommend the following changes:
1 - set the outer wall wipe distance to 0.
2 - set the min wall flow to something like 50.
You may also wish to reduce the max resolution setting from the default value to something smaller as that will make the z-seam wander around less.
Hope this helps.
Hi @burtoogle, Thank you for the suggestions! I will try them.
burtoogle 514
Hello @MarissaP, please save the project file (File -> Save) and attach the .3mf file to this thread. Thanks.
