The "Mark2 for Ultimaker2" printer can be found in the "Other" catagory.
No 'Other' category exist but decided to scroll through each header and stumbled upon 'Foehnsturm -> Mark2 for Ultimaker2'
Many thanks
Sorry, I forgot the “other” category was decommissioned in 4.2
tinkergnome 924
The printer definition is now included in the standard Cura installation (from Version 4.1 on).
If you have copied the json-files to the configuration folder in the past, you may want to clean this up and re-add the printer in Cura, but that's it. There are no manual steps necessary anymore.
danielkrice 4
Ummmmmm...
With a fresh install of 4.2.1, the only reference I can find is Ultimaker Original Duel Extrusion...? Am I missing something? Do I still need to add any config/resource files or is the duel extrusion for the original the same for mark2?
Thanks
