Hi there again, as I am having a look to the axis now and on their alignment I was thinking if it is forth doing it without having the sewing machine oil (as recommended). What do you think, shall I go ahead and do it without oil or is worth to use it whistl doing the alignment?
Many thanks for the suggestions 😃
Smithy 1,141
About the oval shape, I already replied to your other thread, you have to align your axles.
About the problem with the top layer, it would help if you can post a picture here, that we can see what's wrong. Additionally it is also helpful if you save your Cura project as 3mf file and upload it here too, then we have the object and all your Cura settings.
Francesca_T 2
Thank you Smithy. Here is a picture of the 2 tests (apologise the low quality).
I attach the 3mf files as well, hopefully it will help.
We bought some magnalube g and sewing machine oil to realign the axles, hopefully they'll arrive soon.
Pre-sliced file UM2E_20_20_4_calcube_hole.3mf Calibration_Steps.3mf
