I have been using the Octoprint to interface with a Flashforge Creator Pro for over a year. It works for gcode I created in S3D but it is a purely drag and drop. Not bad but not optimum
I am in the process of learning CURA to determine if it has advantages.
Edited by ptwatsadd log file
ahoeben 1,986
I’m the creator of that plugin. The Connect to OctoPrint button should be there regardless of whether OctoPrint is detected on the network. What printer do you want to use OctoPrint with?
Can you upload your cura.log file somewhere and post a link here? It can be found through Help -> Show configuration folder. It should show if something is going wrong with the plugin.
