AndersK 59
Welcome to the forum
I cannot save in x3d in my Creo version but as in most tessellated formats in Creo you probably can, and must, set the chord height.
Set it as low as your model accuracy allows and try again.
Also check if you have any options to set export units.
Otherwise, try the good old stl format but dont forget to set chord height.
Edited by AndersKLink to post
