Cura 4.2.0 printing via USB ???
ksor
Posted · Cura 4.2.0 printing via USB ???
You don't need everything there, so basically download the image, install the software tool to copy the image to the SD card.
If you want to use WiFi you have to put the SD card in your PC/notebook and edit the file mentioned in the instructions.
If done you are ready to boot your Pi from the card and you should be able to access Octopi from your browser.
On the bottom of the download site, there is also a video with the steps.
    Thx again !
