Weird output of gcode Cura 4.2.1
WouterSlegers
Posted · Weird output of gcode Cura 4.2.1
I have a dual extruder setup with a Y-splitter (2 extruders, 1 nozzle) so I had to write some scripts for retracting and priming the materials on every toolchange. Photo's of scripts are included.
Now when I slice a model, the preview shows that everything is fine, however, when I load the gcode on the machine, it goes to one corner and keeps extruding A LOT of material there. When I inserted the gcode into cura to check, it showed that the nozzle wanted to go off the bed into infinity. The fact that my machine does a similar thing means that this is actually what gets exported.
I attached the curaprofile together with all the scripts.
Any help would be greatly appreciated.
Dual Extruder Setup.curaprofile
