1 hour ago, Smithy said:I don't think you have to dry the spool, PLA is not very sensitive to humidity.
Check your PTFE coupler, when the part is worn out, it presses on the filament and you normally see underextrusion. But I can well imagine that the retract won't work that well anymore.
I don't know the eSun filament, but if it is a good quality filament, I see no reason to buy UM material. You can use any manufacturer. So even in your old company it wouldn't have been necessary to buy UM material because of the warranty.
Yeah, I just tried drying because that’s what the filament seller recommended. I’ll definitely check the coupler. I’ve replaced it on the UM2+ extended before, so no big deal.
The eSun has a lot of good reviews on Amazon but there are a few reviews with similar issues regarding the stringing. I stuck to UM filament only because that’s what the reseller told me. I did end up getting a roll of carbon fiber nylon filament from 3DXTech that worked well.
I only mentioned getting the UM filament because it’s normally pretty reliable.
Smithy 1,134
