Heh, I was just waiting for the printer to run that test while I checked the forums for replies. Thanks for the advice, I think it's reasonable. It generally seems ok, but I guess it could be temperamental.
I'm used to pushing 10-15 mm/s on the Prusa, but that's got E3D bits on it. These are direct drive and don't appear to be slipping, and I don't see missing lines nearly everywhere.
I raised the temps a few degrees, and a few more, and the start temps, and it eventually cleaned up. I was at low temps to prevent stringing, though more retraction seems to have helped. It seems to be working so I'm banging out a few test pieces.
It seemed pretty weird because a whole part would print with only a couple weak lines, and always in the same spot. What's up with that? I was printing at 194 Print, 190 Start - now I'm at 200/200.
Smithy 1,088
I would say you print a way too fast and too cold. So you should adjust these values first, before trying something else.
Try your test print with 50mm/s and 200° and check the result. 9.6mm3 is a lot of material which has to be melted in only 1 sec.
