Printing One at a Time is not compatible with multiple extruders in Cura. If you disable the second extruder, you can make the Print Sequence setting visible.
1
2 hours ago, ahoeben said:Printing One at a Time is not compatible with multiple extruders in Cura. If you disable the second extruder, you can make the Print Sequence setting visible.
Tht was it, thanks
Edited by Belachix
Smithy 1,114
Here it is.....
