Posted · lost config after install
i just install the 13.10 and i choose the folder : Cura_13.06.4 for installing
when i restart cura, i don t find my last config.
i work under windows 7.
in witch file is the config when i launch cura ?
thanks
    I don't know how Cura organizes configs on Windows, to be honest. But you can reload the config you used to slice something by using the 'Load Profile from gcode' option. That might be a quick way to get back to where you were.
    Also make sure you run the wizard and select which type of printer you have. This is very important. You don't have to connect to a printer to do this.
    i never generate gcode with cura 13.6.4
    it s so quick no need ....
    so i can t load profile from gcode
    and in linux how cura organize config ?
    i never make save profile.
    before insatlling 13.10 when i launch cura 13.6.4 my config open automatically.
    i never think about saving something
    You did. You just didn't know it. Those gcode files are on your computer somewhere. Search your entire computer for files that include ".gcode".
    i search on my computer in C all *.gcode
    nothing found.
    :eek: :sad:
