Thank you, Mari.
I swear I didn't manually put in a stop at later. I even completely realized and saved with the same result. I'll double check though. Appreciate the feedback
Thank you, Mari.
Remove slicer software, all settings and profiles and re-install... or use another computer 😉
Did you still have the gcode? you could inspect if there are M0/M1/M25 command to pause the print.
If not, it might be firmware.
Jia
Are you having this issue when printing over USB or from SD-card?
Mari 37
In Cura yiu can add Post Processing Scripts, Pause at height is one of them. Once added, you will see a little icon on the slicer screen. Until you click the icon and not delete the script, the printer will stop in every print you create in Gcode.
"pause at height" or other things can't be put by accident in the Gcode-file... 😉
