12 minutes ago, Smithy said:Since you don't give any information which printer you mean, I guess once and assume you mean the S5. The firmware update has only added support for the Material Station, everything else is unchanged. So it has nothing to do with the firmware, but rather with different filaments. Also the color can make a difference.
Yes it is my S5 while I did show two different colors I have ran 9 rolls of this Um black PLA through my printer since purchasing it, and only after the new firmware did I start having this issue, I am printing a new example at -5 temp it should be done in 4 hours, it could also be a nozzle issue I might have installed the left AA in the right side which technically shouldn't make a difference but one is much newer then the other.
Smithy 1,145
