Thank you for the advice - I was referred to this site by Ultimaker (Netherlands).
Please find log files attached.
I'm unfortunately not seeing anything that could explain the issue.
Could you try if the (unofficial) ppa does work (that way we can cross out the appimage as the cause of the problems)?
Or maybe even try one of my x86_64 builds that you can find at https://www.dropbox.com/sh/s43vqzmi4d2bqe2/AAADdYdSu9iwcKa0Knqgurm4a?dl=0 although I would expect the same results as you are seeing with the 4.3 AppImage.
Hi burtoogle
Downloaded your x86_64 builds version 4.2 20190912 and it presents the input screen after accepting the conditions. At least version 4.2 works! Next I shall follow the advice provided by Nallath.
Hi @wrc, well that's something. You could try the 1003 release also as that is based on more recent code from Ultimaker.
Nallath
Not getting any joy from the PPA
An error occurred during a connection to thopiekar.eu. Peer's Certificate has been revoked. Error code: SEC_ERROR_REVOKED_CERTIFICATE
No luck via Pietrowski's PPA either.
burtoogle -
Release 1003 also appears to be fine as regards launching. Would 1003 be equivalent to the latest release 4.3 - as the only reference is Ultimaker Cura Master?
As regards the PPA no luck - Linux Mint 19.2 (Tina) is based on Ubuntu 18.04 (Bionic Beaver), but even installing the PPA does not show the later versions in the PPA. Only version available from the repositories is version 3.1.0.
Now the odd thing is that while leaving the Ultimaker Cura Master (1003) on the system, I downloaded the Appimage 4.3.0 (again! - having previously deleted all files related to Cura and re-installed more than once to no avail) and it now works! Any idea why this might be?
Thanks for the advice and guidance.
Yes, the 1003 release will be fairly similar to 4.3.0. I can't explain why you can now run 4.3.0 also.
remove .cache/cura in your home. It should work
nallath 1,125
For the next time, could you use the github issue tracker (https://github.com/Ultimaker/Cura/issues/) since not all developers are on the forum?
Other than that, could you share the log files? They might contain some info that we can use to fix it.
