Check if your end stop switches are still working. These are the 2 black switches in the back left corner on the top. Turn off you printer and move the head manually the corner and check (hear) if the end stop switch - you can hear a click. If not adjust these switches by loosening the screws a little bit that you can move the switch nearer to the head.
After you have a working end switch you should calibrate the lifting switch, which could be done via the menu on your printer. Just follow the steps there.
Switch are working well, I finally find out that the axis were not parallel anymore (we had an issue with plenty of PLA fooling around the head, and as trying to remove it, we probably pull a little too hard.....)
After setting up the axis correctly, switch were working well again, and I was able to correct the dual material highness changing position following ultimaker procedure.
Smithy 1,108
No need the reset something.
gilbert666 0
Thanks for your answer.
So that's all good for me now!
