I wonder why buildtak sells these plates for the S5 while active leveling can not be disabled.
Since the S5 is measuring at a lot more different locations the buildtak sheet will be ruined after a couple prints because buildtak doesn't like the hot nozzle tip to touch it...
Smithy 753
I don't know if the Buildtak works with the S5, but be aware that you cannot disable the active leveling on the S5.
