Cura starting a circle in mid air (Not able to use support)
Posted
· Cura starting a circle in mid air (Not able to use support)
in Cura under Shell there is a setting called 'outer before inner walls'
This should print the outside wall first and then inner walls.
I dont know what material you are printing with, but you should look at the temperature from the water and the smoke to make sure it does not melt or deform the filament. That would not be very healty to inhale 😉 .
I'm excited because I've personally produced this showcase event, so if you are curious what else I'm up to nowadays, come check it out and say hi in the chat! It would mean a lot!
NickB 2
Hope this solves your problem.
