First Layer with Innofil3D white
ftc
Posted · First Layer with Innofil3D white
Dear Ultimaker-owners,
I attached two pictures of a typical (interrupted) print, I did. The first is the bottom and the second from the top.
Can I improve this? It‘ looks kind of weird and the main problem: the nozzle touches the support while moving after some time.
printer: UM3E
filament: Innofil3D white
nozzle-temp: 215
bed-temp: 70
thanks for your answers!
    To prevent the nozzle from touching the support you can enable the option 'avoid support while traveling' in the travel menu.
    the first layer looks like this because for an UM3(E) the first layer line width is set to 120%, this makes sure that there is plenty of plastic on the botom layer to ensure that the print sticks to the build plate and doesnt come loose during printing.
    This can be fixed by changing the initial layer heigth and the initial line width. But do note that the default initial layer heigth of 0.27mm is much more forgivint to small inacurracies in the build plate than a 0.1mm initial layer heigth
    • Thanks 1
    Thanks for your reply! I‘ll try the avoid option. Does anybody know why some lines are curling? (Look at the red mark to see what I mean. )
    That is also a result of plenty of plastic being extruded during the first layer. It shoulds matter much because this is only a brom as it seems, but maybe the result is better when the brim is disabled. (Personally I only use a brim on thin and long objects)
        • 24 replies
