In my experience the filename will get reset when you do New Project under the File menu but not if you just delete an object and load a new one. But I haven't had the filename persist after quitting cura and restarting it. So until someone gives a better answer try using New Project before loading a new file and see if that works for you.
LindsayPatten 1
rac8006 0
Thanks for the response. I should have known this when I opened the next file and it showed up in addition to the original file.
