Thanks for your reply. If you are referring to the gaps, that is simply coasting being enabled. But I have tried different models and encountered the same issue.
Hello @Curven, please save the project file (File -> Save) and attach the .3mf file to this thread, thanks.
Attached below now. I did some more testing and it looks like the problem goes away if I increase the wall line count, but I would still like to know how to make it work with lower wall line counts, if possible.
Thanks for the file, it definitely looks like a bug to me, I will investigate...
Hello @cdman12, it is indeed a bug which I have fixed and hopefully the fix will make it into a future release.
Awesome, thanks for the quick response!
Curven 28
What I see on your screen shot is that even bigger holes do not have appropriate walls...
So I would rather guess there is a problem with your STL file. Did you allready try to make a new STL with other settings?
