thanks for the tip.
it working but print not working.
whats about the offset from the 2nd extruder?
my offset is -30;2 for the 2nd extruder to hit the same point from the first one.
so when i start to print with the modifaction from the gcode the print starts outside from the bed.
any ideas?
Daid 303
Currently Cura always uses the primary extruder for single color objects.
However, if you edit the start.gcode and insert:
at the front, it will use the 2nd extruder from that point on. (Use T0 for the primary)
