Mesh leveling is a feature where it takes many measurements of your build plate by pushing the head down onto the bed many times. Typically at least a grid of 4X4 or 16 measurements. This data is called a "mesh" as it resembles a 3d graphics concept - like a map of mountains/hills. Anyway the M420 command enables the mesh leveling.
I know nothing about your printer but is it possible that you never did a multi point leveling? Maybe you should just get rid of that M420 command to see what happens. Or maybe you need to run the multipoint leveling once before you start your print?
I would try to find a creality forum somewhere and those people should know immediately what your issue is.
gr5 1,841
It looks fine to me. I don't understand the M420 command. I'm not familiar with that - it's not a UM (ultimaker) standard. According to this:
https://reprap.org/wiki/G-code#M420:_Leveling_On.2FOff.2FFade_.28Marlin.29
The "Z2" means mesh compensation ends at Z=2mm (so it compensates from Z=0 until Z=2).
Could it be that your mesh compensation values are off?
I'm adding "cr20" to your topic title so that people who own a creality will notice your topic. This is an Ultimaker forum so most people own Ultimakers or have cura questions. Your question is cura related but is more of a creality specific question.
alphaomega 0
Hi, there.
Thank's for replying , I know nothing about mesh :(.
