Issue with printing PP
mike4it
Posted · Issue with printing PP
I have an issue when I print PP. As you can see on the pictures there is one side (bottom side) of the print that is a real mess. That area is where the head gets up and down to change position. Is someone ever experiences some similar issues and could help me with this ?
Here are the settings I used:
- fan speed at 75%
- infill density 105%
- build plate temp. 100°C
- printing temp. 230°C
I also tried those settings but got the same result:
- fan speed at 0%
- infill density 125%
- build plate temp. 85°C
- printing temp. 210°C
Thanks
    Thanks for your answer.
    I tried to set "Z Seam Alignment" to Random but I still get the same result...
    Retraction Distance is set to 6.5mm
    Do you think I should change this value?
    I also tried to set Retraction Extra Prime Amount to 1 mm3 but same result.
    I don't think it's under extrusion because it only affects one area of the print. I also checked the bed level.
