It's because the model is not optimised for 3D printing. There's a lot of fine details in the .stl that are not printed. eg. the walls under the hatch is to thin for Cura to print them. and this messes up the support.
if you set the nozzle to 0.3 they will print and you will get the support.
please note that theres still a lot of the other walls that ar not printed because they are to thin.
I am not sure if theres a setting in Cura that will let you print everything thing whit a minimum 1 wall thickness.
Edit:
Sorry I didn't notice that you have the thin walls printing. are you upscaling the model?
Can you try and save as a Cura project instead of the .3mf so I can see the settings.
Edited by NBull
NBull 14
Hej Roldy
Edit:
Edited by NBullLink to post
