Attached are files. I have reduced my model as much as I can while the problem still reproduces.
In the first image you will see highlighted in yellow what the model looks like on the bottom In the second image you see what Cura is producing for the first layer. Notice that the hole is missing in Cura's slicing of the first layer.
Notice in the model a line that is on the right-facing wall about 10% up from the floor. I'd this line is deleted, the problem disappears. However, I have carefully looked inside the model and it is not forming a floor or compartment...it's just a line. Similarly, deleting other structures like the girl on the end also causes the problem to disappear.
Also attached are two partial X-Ray views showing that there is no floor or structure that intersects the "chimney with the curved top" to create any sort of a floor.
Any help that can be offered with this would be appreciated. I have spent a long time on this. The actual model is very complex, and recreating it would take a month or so...so I would love to know what either the problem is or what the workaround is. Do I have a bad setting? Is this a known bug?
CPD 2019-11-25X.3mf CPD 2019-11-25X.stl CPD 2019-11-25X.skp.zip
burtoogle 515
Could you please save the Cura project (File -> Save) and attach the resulting .3mf file to this thread. Thanks.
