Cura 4.4.0 autostart from Fusion 360 ??
ksor
Posted · Cura 4.4.0 autostart from Fusion 360 ??
I had this behavior also with previous version of Cura. On the Mac it is a permission issue, that Fusion is not allowed to start other applications.
    23 minutes ago, Carla_Birch said:
    Cura needs to be open before Fusion 360 will export the stl to it, it's a problem with the MacOS, so just click to open fusion from the dock and then open fusion 360 and go about things as normal.
    I'm running Windows and it used to be NO problem starting Cure automatically - but.4.0 wont do it !
