SD card lost communication suddenly
zebrajack
Posted · SD card lost communication suddenly
Hi, there.
My ultimaker derivative suddenly stop due to sd data communication loss.It may cause by signal interfence .Does anyone encounter the same problem? How to solve the problem.
Regards!
Cheng
    Since you are using a cloned machine (if I understand you correctly), it's unlikely that anyone is able to help since we don't know how it's built.
    However, there is a bug in the current firmware which may be causing this issue (if that's what your machine is using...). Update will be out on Monday.
    That update might only be related to Ultimaker 2's. Daid hasn't given out much details on that issue. I think the update is a firmware update but even that I'm unclear on.
