Bildplate temperature
cigarass
Posted · Bildplate temperature
Hello Community,
When the printer starts, the temperature of the bildplate goes slowly from 60 to 20, what can I do about it ?
I installed the last firmware, the printer is an ultimaker original +.
I hope someone has a solution, thank you,
greeting ruud
    I've tried it with others, but now the bildplate doesn't warm up at all anymore, so it's not the G-Code
    I heard that the connectors at the back of the build plate are kinda weak. Could you look if these are still attached correctly?
    I looked at the connection on the plate itself, and the plug on the motherboard. Everything looked good, maybe the heating element is broken, can you test that?
        • 31 replies
        • 25 replies
