Cura 4.4 configuration errors
Bartje64
Posted · Cura 4.4 configuration errors
Hello, hope someone in the community can give me some insight into my issue.
My OS in Win10 64bit.
I had been using Cura 4.2.1 with success but it told me an update was available to 4.4 so this was installed.
Opened it the first time, no problems and set up / checked my printer configuration did some printing and closed the program.
Since that time , anytime I open the program I get a message stating I have "configuration errors", "Something seems to be wrong with the following profiles".
Each time I open the program the list appears to be getting longer.
I close the message and can continue without issues but what is causing this?
