Thanks for the reply. I moved the circles and as you suspected, the gray goes away. I took a look at the discussion about Sketchup. The Solid Inspector does check for reversed faces and will fix them automatically most of the time. My prints have gotten much more reliable with this plugin.
I appreciate your comments about the nozzle image. I thought it was some kind of warning/error indicator. I feel much better knowing its not.
1
gr5 2,071
Do you also see the horizontal dark blue line near the bottom of your image? If you click on the circle and drag it then you will see that nozzle moving around. There's also a vertical line off the side of the photo. Drag that and the gray goes away.
The gray I think is a minor bug but as soon as you start dragging the thing at the right it is good.
Sketchup is not designed to make solids so it's easy to make mistakes in sketchup. i strongly recommend you do a 2 minute quick scan of this document. Particularly the part about "reverse faces":
https://i.materialise.com/blog/3d-printing-with-sketchup/
