And by this, @burtoogle means that as long as the firmware accepts X & Y coordinates ("cartesian") and does the inverse kinematics calculation for your scara setup, it should work with Cura. Cura will not do the actual motion conversion for you.
SCARA printers often have a non-rectangular buildvolume. That will be a bit of work to fully support in Cura.
Edited by ahoeben
burtoogle 516
If the machine accepts "standard" gcode, then Cura should be able to slice for it. Do you know what controller/firmware the machine uses?
ahoeben 2,047
Edited by ahoebenLink to post
