Frist print
DocHoliday
Posted (edited) · Frist print
Hi guys,
I just put together my Ender 5 and wondered what to print first. Having just broken the cover of my mobile I went searching for one and quickly found one.
Printing it turned out to be more difficult than finding it. As you can see in the pictures the top part is ok but the bottom part is to narrow. Can you point me in the direction of what can be wrong?
Nozzle was set to 200 and bed to 60 degrees
Thank you
Edited by DocHoliday
    Posted · Frist print
    1 minute ago, DidierKlein said:
    Hi @DocHoliday
    Yes the post is approved but it seems no one can help you on your issue.
    If the fit is to narrow maybe you can simply increase the size a tiny bit in cura and print it again
    Hi Didier,
    Ok thank you. I just saw the message your content will need to be approved but it will be about my next post not the top one.
