Hi, I know it has been a while but I add a similar problem and also a solution:
I tried it the same way as you: providing a json file,the stl and feeding all the parameters in a text. file.
All the parameters were recovered from a .log file recovered from the log file after a slice with the machine on a file. The thing is I always add something wrong with the parameters at some points and it's hard to debug and understand which fails and why when there is more than 400 parameters.
So I tried another way: feeding the parameters directly in the fdmprinter.def.json
This is a json file! : Get your profile from the log into a dictionnary, parkour your fdmprinter.def.json and change the default value by the one you got from the log.
Thanks to that, the only trouble remaning when you do:
curaengine slice -j output.def.json -l cube.stl -o output.gcode
is that you get the error:
[ERROR] Trying to retrieve setting with no value given: 'machine_extruder_cooling_fan_number'
But you can solve the problem by doing:
curaengine slice -j output.def.json -s machine_extruder_cooling_fan_number="0" -l cube.stl -o output.gcode
Also the problem may come from I am a beginner at programming but at the end it works ^^.
1
1
reomalley16 0
I can provide the .stl for this file if that'll help too, but
here is the -v output from CuraEngine during the slicing process:
Cura_SteamEngine version master
Copyright (C) 2019 Ultimaker
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU Affero General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU Affero General Public License for more details.
You should have received a copy of the GNU Affero General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
[WARNING] Unrecognized data type in JSON setting machine_disallowed_areas
[WARNING] Unrecognized data type in JSON setting nozzle_disallowed_areas
[WARNING] Unrecognized data type in JSON setting machine_head_with_fans_polygon
[WARNING] JSON setting gantry_height has no default_value!
loading 'Flattened_Lapras.stl' took 0.001 seconds
Loaded from disk in 0.006s
[WARNING] -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s mesh_position_y="0" -s center_object="false" -s small_feature_speed_factor_0="50" -s small_feature_speed_factor="50" -s small_feature_max_length="0" -s wipe_hop_speed="10" -s wipe_hop_amount="1" -s wipe_hop_enable="true" -s wipe_pause="0" -s wipe_retraction_retract_speed="3" -s wipe_retraction_amount="1" -s max_extrusion_before_wipe="10" -s clean_between_layers="false" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s bridge_skin_material_flow_3="110" -s bridge_skin_speed_3="15" -s bridge_fan_speed_2="0" -s bridge_skin_density_2="75" -s bridge_skin_speed_2="25" -s bridge_enable_more_layers="true" -s bridge_skin_density="100" -s bridge_wall_material_flow="50" -s bridge_sparse_infill_max_density="0" -s bridge_skin_support_threshold="50" -s wall_overhang_angle="90" -s adaptive_layer_height_variation_step="0.01" -s adaptive_layer_height_enabled="false" -s wireframe_nozzle_clearance="1" -s wireframe_roof_outer_delay="0.2" -s wireframe_roof_fall_down="2" -s wireframe_straight_before_down="20" -s wireframe_strategy="compensate" -s wireframe_drag_along="0.6" -s wireframe_fall_down="0.5" -s wireframe_top_jump="0.6" -s wireframe_up_half_speed="0.3" -s wireframe_bottom_delay="0" -s wireframe_top_delay="0" -s wireframe_flow_connection="100" -s wireframe_printspeed_flat="5" -s wireframe_printspeed_down="5" -s wireframe_printspeed_up="5" -s wireframe_printspeed_bottom="5" -s adaptive_layer_height_variation="0.1" -s flow_rate_extrusion_offset_factor="100" -s flow_rate_max_extrusion_offset="0" -s wipe_retraction_enable="true" -s magic_fuzzy_skin_point_dist="0.8" -s magic_fuzzy_skin_thickness="0.3" -s wireframe_flat_delay="0.1" -s magic_fuzzy_skin_enabled="false" -s support_conical_angle="30" -s support_conical_enabled="false" -s spaghetti_inset="0.2" -s spaghetti_max_height="2" -s spaghetti_infill_enabled="false" -s cross_infill_density_image="" -s cross_infill_pocket_size="2" -s coasting_speed="90" -s conical_overhang_enabled="false" -s draft_shield_height="10" -s draft_shield_height_limitation="full" -s draft_shield_dist="10" -s draft_shield_enabled="false" -s wipe_repeat_count="5" -s bridge_fan_speed_3="0" -s support_skip_some_zags="false" -s minimum_polygon_circumference="1" -s material_flow_dependent_temperature="false" -s roofing_pattern="lines" -s slicing_tolerance="middle" -s support_tree_collision_resolution="0.4" -s support_tree_branch_diameter_angle="5" -s support_tree_branch_distance="1" -s support_tree_angle="40" -s smooth_spiralized_contours="true" -s coasting_min_volume="0.8" -s magic_mesh_surface_mode="normal" -s mold_angle="40" -s mold_roof_height="0.5" -s mold_width="5" -s mold_enabled="false" -s cutting_mesh="false" -s meshfix_maximum_travel_resolution="1" -s meshfix_maximum_resolution="0.5" -s remove_empty_first_layers="true" -s alternate_carve_order="true" -s wireframe_height="3" -s ooze_shield_dist="2" -s ooze_shield_angle="60" -s prime_tower_position_y="200" -s prime_tower_position_x="200" -s prime_tower_min_volume="6" -s prime_tower_size="20" -s prime_tower_enable="false" -s raft_base_fan_speed="0" -s raft_interface_fan_speed="0" -s raft_base_jerk="20" -s raft_interface_jerk="20" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="3000" -s raft_interface_acceleration="3000" -s cool_min_layer_time="5" -s material_break_preparation_speed="2" -s material_break_preparation_retracted_position="-16" -s material_anti_ooze_retraction_speed="5" -s material_crystallinity="false" -s raft_base_line_spacing="1.6" -s material_bed_temperature="60" -s default_material_bed_temperature="60" -s material_final_print_temperature="195" -s wall_x_material_flow="100" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s wall_line_count="2" -s coasting_enable="false" -s support_infill_sparse_thickness="0.1" -s default_material_print_temperature="210" -s material_surface_energy="100" -s cross_support_density_image="" -s switch_extruder_retraction_amount="20" -s raft_base_speed="15" -s skin_edge_support_layers="4" -s print_sequence="all_at_once" -s support_xy_distance_overhang="0.2" -s infill_support_enabled="false" -s infill_before_walls="true" -s infill_overlap_mm="0.04" -s sub_div_rad_add="0.4" -s infill_multiplier="1" -s zig_zaggify_infill="false" -s infill_pattern="grid" -s material_adhesion_tendency="10" -s support_tree_enable="false" -s skin_overlap_mm="0.02" -s machine_heat_zone_length="16" -s machine_max_jerk_e="5" -s acceleration_ironing="3000" -s speed_infill="60" -s speed_ironing="20" -s raft_surface_jerk="20" -s speed_z_hop="10" -s ironing_inset="0.35" -s ironing_line_spacing="0.1" -s retraction_hop_after_extruder_switch_height="1" -s material_initial_print_temperature="200" -s mesh_position_x="0" -s bridge_settings_enabled="false" -s ironing_only_highest_layer="false" -s meshfix_maximum_deviation="0.05" -s infill_wipe_dist="0.04" -s spaghetti_infill_extra_volume="0" -s spaghetti_max_infill_angle="10" -s infill_line_width="0.4" -s roofing_material_flow="100" -s infill_wall_line_count="0" -s roofing_angles="[ ]" -s support_tree_branch_diameter="2" -s z_seam_corner="z_seam_corner_inner" -s infill_material_flow="100" -s z_seam_y="100" -s infill_support_angle="40" -s machine_firmware_retract="false" -s raft_surface_thickness="0.1" -s machine_nozzle_size="0.4" -s brim_line_count="20" -s ironing_enabled="false" -s support_zag_skip_count="5" -s skirt_gap="3" -s z_seam_x="100" -s xy_offset="0" -s wall_min_flow="0" -s prime_tower_line_width="0.4" -s filter_out_tiny_gaps="true" -s support_fan_enable="false" -s infill_sparse_thickness="0.1" -s support_mesh="false" -s travel_compensate_overlapping_walls_0_enabled="true" -s infill_extruder_nr="-1" -s wireframe_enabled="false" -s material_diameter="1.75" -s travel_compensate_overlapping_walls_x_enabled="true" -s support_bottom_material_flow="100" -s jerk_print_layer_0="20" -s bridge_wall_min_length="5" -s alternate_extra_perimeter="false" -s bridge_wall_speed="15" -s meshfix_union_all_remove_holes="false" -s xy_offset_layer_0="0" -s outer_inset_first="false" -s optimize_wall_printing_order="false" -s support_roof_line_width="0.4" -s wall_0_inset="0" -s top_layers="8" -s material_break_temperature="50" -s skin_angles="[ ]" -s prime_tower_brim_enable="false" -s bottom_layers="6" -s speed_wall_0="30" -s speed_support_infill="60" -s gradual_infill_steps="0" -s switch_extruder_extra_prime_amount="0" -s cool_fan_speed_min="100" -s acceleration_support_infill="3000" -s infill_mesh_order="0" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50" -s raft_surface_fan_speed="0" -s machine_filament_park_distance="16" -s z_seam_relative="false" -s initial_bottom_layers="6" -s extruder_prime_pos_abs="false" -s material_flow_layer_0="100" -s material_standby_temperature="150" -s ironing_pattern="zigzag" -s machine_heated_build_volume="false" -s top_skin_expand_distance="1" -s infill_randomize_start_location="false" -s layer_0_z_overlap="0.22" -s machine_nozzle_tip_outer_diameter="1" -s skin_no_small_gaps_heuristic="false" -s machine_height="370" -s machine_buildplate_type="glass" -s material_anti_ooze_retracted_position="-4" -s support_roof_angles="[ ]" -s layer_height_0="0.3" -s skirt_brim_speed="30" -s support_enable="false" -s machine_extruder_count="1" -s wipe_move_distance="20" -s skin_line_width="0.4" -s material_shrinkage_percentage="0" -s machine_name="Unknown" -s initial_layer_line_width_factor="100" -s top_skin_preshrink="1" -s bridge_fan_speed="100" -s ooze_shield_enabled="false" -s machine_center_is_zero="true" -s machine_nozzle_expansion_angle="45" -s extruder_prime_pos_z="0" -s connect_infill_polygons="true" -s infill_line_distance="2" -s material_guid="" -s support_conical_min_width="5" -s gradual_infill_step_height="1.5" -s material_bed_temp_wait="true" -s spaghetti_flow="20" -s prime_tower_wipe_enabled="true" -s layer_start_y="0" -s material_break_speed="25" -s machine_show_variants="false" -s machine_nozzle_head_distance="3" -s skirt_brim_line_width="0.4" -s speed_support_bottom="40" -s support_type="everywhere" -s travel_avoid_distance="0.625" -s material_print_temperature_layer_0="215" -s material_bed_temperature_layer_0="60" -s roofing_layer_count="0" -s jerk_travel="30" -s machine_max_feedrate_z="2.99792e+11" -s min_skin_width_for_expansion="2.24" -s machine_acceleration="4000" -s machine_depth="260" -s support_connect_zigzags="true" -s support_bottom_offset="0" -s jerk_ironing="20" -s support_bottom_distance="0.1" -s infill_mesh="false" -s raft_margin="15" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s material_print_temp_prepend="true" -s connect_skin_polygons="false" -s machine_max_acceleration_y="9000" -s machine_use_extruder_offset_to_offset_coords="true" -s machine_endstop_positive_direction_x="false" -s machine_nozzle_heat_up_speed="2" -s min_infill_area="0" -s layer_start_x="0" -s support_brim_enable="false" -s bottom_skin_preshrink="1" -s machine_nozzle_temp_enabled="true" -s skirt_line_count="1" -s support_tower_maximum_supported_diameter="3" -s machine_max_feedrate_x="2.99792e+11" -s machine_gcode_flavor="Repetier" -s material_extrusion_cool_down_speed="0.7" -s material_bed_temp_prepend="true" -s retraction_combing_max_distance="0" -s top_bottom_pattern="lines" -s machine_max_feedrate_y="2.99792e+11" -s support_mesh_drop_down="true" -s infill_offset_x="0" -s machine_max_acceleration_x="9000" -s fill_outline_gaps="false" -s coasting_volume="0.064" -s wall_x_extruder_nr="-1" -s bridge_skin_material_flow_2="100" -s machine_endstop_positive_direction_y="false" -s gradual_support_infill_step_height="1" -s machine_max_acceleration_z="100" -s machine_start_gcode="G21
G90
M82
M107 T0
M190 S{material_bed_temperature}
M109 S{material_print_temperature} T0
G28
G92 E0
G0 E3 F200
G92 E0
" -s machine_max_acceleration_e="10000" -s mesh_position_z="0" -s speed_prime_tower="60" -s wall_line_width_0="0.4" -s raft_interface_speed="15" -s infill_offset_y="0" -s travel_avoid_supports="false" -s machine_steps_per_mm_x="50" -s switch_extruder_prime_speed="20" -s acceleration_wall_0="3000" -s ironing_flow="10" -s support_extruder_nr_layer_0="0" -s support_roof_extruder_nr="0" -s support_initial_layer_line_distance="2.66" -s machine_steps_per_mm_z="50" -s machine_extruders_share_heater="false" -s machine_steps_per_mm_e="1600" -s wall_0_extruder_nr="-1" -s spaghetti_infill_stepped="true" -s support_roof_material_flow="100" -s machine_endstop_positive_direction_z="true" -s machine_nozzle_cool_down_speed="2" -s machine_steps_per_mm_y="50" -s machine_minimum_feedrate="0" -s speed_wall_x="60" -s layer_height="0.1" -s wall_line_width_x="0.4" -s raft_surface_line_width="0.4" -s machine_feeder_wheel_diameter="10" -s infill_angles="[ ]" -s top_bottom_pattern_0="lines" -s machine_max_feedrate_e="2.99792e+11" -s cool_fan_speed_max="100" -s roofing_extruder_nr="-1" -s cool_min_layer_time_fan_speed_max="10" -s machine_max_jerk_xy="20" -s support_line_width="0.4" -s support_wall_count="1" -s support_bottom_line_width="0.4" -s anti_overhang_mesh="false" -s top_bottom_extruder_nr="-1" -s wireframe_roof_inset="3" -s skin_material_flow="100" -s retraction_count_max="90" -s skirt_brim_material_flow="100" -s retraction_combing="all" -s wipe_retraction_prime_speed="2" -s support_material_flow="100" -s machine_nozzle_id="unknown" -s support_bottom_pattern="concentric" -s prime_tower_flow="100" -s infill_sparse_density="10" -s retraction_enable="true" -s retract_at_layer_change="false" -s carve_multiple_volumes="true" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s retraction_retract_speed="25" -s material_print_temp_wait="true" -s support_bottom_height="1" -s gantry_height="1e+11" -s support_interface_skip_height="0.3" -s acceleration_enabled="false" -s z_seam_type="back" -s retraction_prime_speed="25" -s retraction_extra_prime_amount="0" -s retraction_min_travel="1.5" -s retraction_extrusion_window="4.5" -s bottom_skin_expand_distance="1" -s build_volume_temperature="0" -s switch_extruder_retraction_speed="20" -s speed_roofing="25" -s jerk_travel_layer_0="20" -s speed_topbottom="30" -s conical_overhang_angle="50" -s material_print_temperature="210" -s speed_support_roof="40" -s speed_travel="120" -s minimum_roof_area="1" -s speed_slowdown_layers="2" -s speed_equalize_flow_enabled="false" -s acceleration_infill="3000" -s acceleration_wall_x="3000" -s retraction_hop_enabled="false" -s acceleration_roofing="3000" -s skin_outline_count="1" -s acceleration_topbottom="3000" -s acceleration_support_roof="3000" -s acceleration_support_bottom="3000" -s machine_width="260" -s acceleration_travel_layer_0="3000" -s relative_extrusion="false" -s adhesion_extruder_nr="0" -s multiple_mesh_overlap="0.15" -s machine_max_jerk_z="0.4" -s acceleration_prime_tower="3000" -s support_pattern="zigzag" -s acceleration_travel="5000" -s limit_support_retractions="true" -s acceleration_print_layer_0="3000" -s support_offset="0" -s jerk_enabled="false" -s wall_min_flow_retract="false" -s jerk_infill="20" -s jerk_wall_0="20" -s jerk_wall_x="20" -s infill_enable_travel_optimization="false" -s cool_fan_full_layer="2" -s wipe_brush_pos_x="100" -s bridge_skin_speed="15" -s raft_surface_acceleration="3000" -s jerk_roofing="20" -s jerk_topbottom="20" -s support_use_towers="true" -s jerk_support_infill="20" -s wireframe_roof_drag_along="0.8" -s jerk_support_roof="20" -s support_tree_wall_count="1" -s extruders_enabled_count="1" -s extruder_prime_pos_y="0" -s jerk_support_bottom="20" -s adaptive_layer_height_threshold="0.2" -s support_roof_pattern="concentric" -s jerk_prime_tower="20" -s jerk_skirt_brim="20" -s wall_0_wipe_dist="0.2" -s travel_retract_before_outer_wall="false" -s speed_equalize_flow_max="150" -s support_infill_extruder_nr="0" -s travel_avoid_other_parts="true" -s retraction_hop_only_when_collides="false" -s retraction_hop="1" -s retraction_hop_after_extruder_switch="true" -s cool_fan_speed_0="0" -s cool_lift_head="false" -s speed_travel_layer_0="60" -s support_bottom_extruder_nr="0" -s support_angle="50" -s speed_print_layer_0="30" -s machine_shape="elliptic" -s support_line_distance="2.66" -s material_break_preparation_temperature="50" -s support_infill_angles="[ ]" -s support_xy_overrides_z="z_overrides_xy" -s skirt_brim_minimal_length="250" -s support_brim_line_count="20" -s support_top_distance="0.1" -s cool_fan_enabled="true" -s support_xy_distance="0.7" -s magic_spiralize="false" -s support_bottom_stair_step_height="0.3" -s machine_heated_bed="true" -s support_bottom_stair_step_width="5" -s support_join_distance="2" -s gradual_support_infill_steps="0" -s minimum_support_area="0" -s support_roof_enable="false" -s support_bottom_enable="false" -s support_roof_height="1" -s support_roof_line_distance="0.4" -s brim_outside_only="true" -s support_bottom_line_distance="0.4" -s meshfix_keep_open_polygons="false" -s minimum_bottom_area="1" -s support_roof_offset="0" -s support_bottom_angles="[ ]" -s wireframe_flow_flat="100" -s roofing_line_width="0.4" -s adhesion_type="brim" -s raft_base_line_width="0.8" -s support_supported_skin_fan_speed="100" -s support_tower_diameter="3" -s support_tower_roof_angle="65" -s prime_blob_enable="false" -s meshfix_union_all="true" -s extruder_prime_pos_x="0" -s brim_replaces_support="true" -s raft_smoothing="5" -s bridge_skin_material_flow="60" -s raft_airgap="0.3" -s raft_surface_layers="2" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s raft_interface_thickness="0.15" -s meshfix_extensive_stitching="false" -s acceleration_skirt_brim="3000" -s raft_interface_line_width="0.7" -s raft_interface_line_spacing="0.9" -s zig_zaggify_support="false" -s machine_end_gcode="M107 T0
M104 S0
M104 S0 T1
M140 S0
G92 E0
G91
G1 E-1 F300
G1 Z+0.5 E-5 X-20 Y-20 F9000
G28 X0 Y0
M84 ;steppers off
G90 ;absolute positioning
" -s raft_base_thickness="0.3" -s raft_surface_speed="20" -e0 -s machine_nozzle_offset_y="0" -s extruder_prime_pos_z="0" -s machine_nozzle_offset_x="0" -s extruder_nr="0" -s machine_extruder_end_pos_y="0" -s material_diameter="1.75" -s machine_nozzle_id="unknown" -s machine_nozzle_size="0.4" -s extruder_prime_pos_x="0" -s machine_extruder_start_pos_abs="false" -s machine_extruder_start_pos_y="0" -s machine_extruder_start_code="" -s machine_extruder_end_pos_x="0" -s machine_extruder_end_code="" -s extruder_prime_pos_y="0" -s machine_extruder_start_pos_x="0" -s machine_extruder_end_pos_abs="false" -s machine_extruder_cooling_fan_number="0" -g -e0 -l "0" -s acceleration_wall_x="3000" -s support_tower_diameter="3.0" -s wireframe_drag_along="0.6" -s material_shrinkage_percentage="0" -s material_break_temperature="50" -s optimize_wall_printing_order="False" -s support_tree_collision_resolution="0.2" -s skin_no_small_gaps_heuristic="False" -s support_tree_branch_distance="1" -s expand_skins_expand_distance="0.8" -s initial_layer_line_width_factor="100.0" -s support_interface_height="1" -s top_skin_preshrink="0.8" -s min_infill_area="0" -s machine_height="370" -s wall_0_inset="0" -s machine_acceleration="4000" -s support_bottom_pattern="concentric" -s gradual_support_infill_step_height="1" -s alternate_extra_perimeter="False" -s magic_fuzzy_skin_thickness="0.3" -s jerk_support_bottom="20" -s machine_start_gcode="G21" -s support_initial_layer_line_distance="2.6666666666666665" -s wall_thickness="1" -s retraction_prime_speed="25" -s top_bottom_pattern="lines" -s z_seam_relative="False" -s speed_wall_0="40" -s bottom_skin_expand_distance="0.8" -s prime_blob_enable="False" -s machine_filament_park_distance="16" -s extruder_prime_pos_z="0" -s speed_wall="30.0" -s machine_max_acceleration_e="10000" -s skin_preshrink="0.8" -s machine_heated_bed="True" -s machine_show_variants="False" -s layer_height_0="0.3" -s raft_base_acceleration="3000" -s acceleration_print="3000" -s bridge_skin_density_2="75" -s support_bottom_angles="[ ]" -s magic_fuzzy_skin_enabled="False" -s layer_start_y="0.0" -s bridge_settings_enabled="False" -s support_interface_line_width="0.4" -s skirt_brim_line_width="0.4" -s machine_extruder_start_pos_x="0" -s extruder_nr="0" -s machine_extruder_end_pos_y="0" -s support_bottom_stair_step_height="0.3" -s material_diameter="1.75" -s support_fan_enable="False" -s machine_nozzle_id="unknown" -s machine_nozzle_size="0.4" -s extruder_prime_pos_x="0" -s machine_extruder_start_pos_abs="false" -s material_bed_temperature_layer_0="60" -s center_object="True" -s machine_depth="260" -s travel_retract_before_outer_wall="False" -s support_infill_extruder_nr="0" -s wall_min_flow_retract="False" -s machine_nozzle_expansion_angle="45" -s machine_extruder_start_code="" -s zig_zaggify_infill="False" -s skirt_line_count="1" -s infill_support_angle="40" -s raft_base_line_spacing="1.6" -s machine_extruder_end_pos_x="0" -s infill_offset_x="0" -s minimum_polygon_circumference="1.0" -s machine_extruder_end_code="" -s material_adhesion_tendency="10" -s jerk_layer_0="20" -s extruder_prime_pos_y="0" -s retraction_combing_max_distance="0" -s machine_extruder_end_pos_abs="false" -s raft_interface_jerk="20" -s material_print_temperature_layer_0="210" -s machine_extruder_cooling_fan_number="0" -s fill_perimeter_gaps="everywhere" -s roofing_layer_count="0" -s support_top_distance="0.1" -s xy_offset="0" -s travel_speed="120" -s day="Wed" -s acceleration_support_interface="3000" -s support_brim_enable="False" -s support_interface_skip_height="0.3" -s skin_line_width="0.4" -s material_break_retracted_position="-50" -s wireframe_printspeed="5" -s support_conical_min_width="5.0" -s speed_z_hop="10" -s switch_extruder_prime_speed="20" -s infill_material_flow="100" -s support_interface_pattern="concentric" -s machine_extruder_start_pos_y="0" -s retraction_amount="6.5" -s support_bottom_height="1" -s z_seam_corner="z_seam_corner_inner" -s support_interface_angles="[ ]" -s machine_max_jerk_z="0.4" -s wall_0_material_flow="100" -s wall_extruder_nr="-1" -s support_conical_angle="30" -s machine_nozzle_offset_x="0" -s raft_surface_fan_speed="0" -s machine_nozzle_heat_up_speed="2.0" -s material_break_preparation_retracted_position="-16" -s retraction_retract_speed="25" -s infill_sparse_density="10" -s raft_fan_speed="0" -s support_xy_distance="0.7" -s support_extruder_nr_layer_0="0" -s jerk_wall_x="20" -s extruder_prime_pos_abs="False" -s retraction_count_max="90" -s magic_fuzzy_skin_point_dist="0.8" -s machine_nozzle_offset_y="0" -s machine_max_feedrate_x="299792458000" -s acceleration_infill="3000" -s wireframe_flow_connection="100" -s speed_support_bottom="40.0"
Progress: start accomplished in 0.000s
Starting slice...
Slicing model...
slice of mesh took 0.005 seconds
slice make polygons took 0.003 seconds
Progress: slice accomplished in 0.008s
Starting layerparts...
Progress: layerparts accomplished in 0.004s
Starting inset+skin...
Layer count: 200
Progress: inset+skin accomplished in 0.347s
Starting support...
Processing platform adhesion
Progress: support accomplished in 0.056s
Starting export...
Multithreading GcodeLayerThreader with 1 threads.
Progress: export accomplished in 0.440s
Total time elapsed 0.86s.
Gcode header after slicing:
;FLAVOR:Repetier
;TIME:1241
;MINX:-23.26
;MINY:-15.129
;MINZ:0.3
;MAXX:23.261
;MAXY:19.979
;MAXZ:20.2
End of gcode header.
Print time (s): 1241
Print time (hr|min|s): 0h 20m 41s
Filament (mm^3): 1462
