Posted · Does not download settings from Cura
Hello.
Excuse my weak English, I use a translator. I have a problem with my CR-10S PRO. I'm printing from a MicroSD card. The printer does not download all the settings I set in Cura. For example, the hotend temperature and print speed, I have to set the printer before each print. In Cura I have set the temperature for the first layer of 200 ° C and for the other layers the same. When I enter to print, the temperature is 0 ° C and I have to manually set 200. In Cura I have set the print speed to 50, but the printer is set to 100 and I have to manually set 50.
In Cura it is possible to set different versions of G-code. Which is right for my CR-10S PRO?
Thank you for your willingness.
    Which one have you set it to?
    I'm fairly certain it should be "Marlin" for all Creality printers.
    Posted (edited) · Does not download settings from Cura
    So, the temperatures work, but the hotbed first heats up and then the hotend heats up.
    Here it is written
    https://community.ultimaker.com/topic/26391-start-heating-bed-and-extruder-and-level-bed-at-the-same-time/
    I still have to find out why he is not pushing at 50 but at 100.
    Edited by mclareniak
    Well, Marlin firmware let you change the printing speed (feed rate) as a percentage value.
    That means, you are printing with 100% of 50mm/s (if the displays shows 100).
    If you change it during a print, be aware that the feedrate percentage applies to all moves in all axes.
    Now I understand. So it pushes at 50, but when I select 50 on the display, it actually pushes 25.
    Thanks for the explanation.
    Hello.
    So I found out that in Cura I set the speeds as follows:
    first layer 25mm / s and other 50mm / s.
    But the printer prints everything at 25mm / s.
    Can't you tell me where it's wrong?
    Well thank you.
