Posted · Authenticating Ultimaker 3 with HTTPDigest & Python3 requests lib
Hello, as title says, not having success figuring out HTTPDigest.
Below I've attached both the code I'm trying to use and all the results I could think to log.
Curiously I cannot get put requests working via the API at all, attempting to rename my printer has resulted in it now being called "none"?
I did successfully retrieve and validate a key/password pair though.
I'm trying to change the LED colour with a python script, any help in the right direction would be greatly appreciated :)
    9 hours ago, nicholairank said:
    I'm trying to change the LED colour with a python script, any help in the right direction would be greatly appreciated 🙂
    @Daid uses a session object in his demo script, dunno if it makes a difference.
    The code examples in the "Inside..." topics are a bit scrambled since one of the forum updates.
    Here is the demo script in a usable state:
    https://community.ultimaker.com/topic/30437-trying-to-find-a-command-that-changes-the-current-state-of-the-printer-from-printing-to-pause-and-vice-versa/?do=findComment&comment=252483
    11 hours ago, nallath said:
    Did you already check these topics?
    Yeah I'd already been over Daid's docs, thanks though.
    This is ridiculously handy, thanks a heap, have the example working so I guess I'll build from there, cheers 🙂
    New questions / issues with running a print job however:
    image.thumb.png.359e3d9e07abaa8897bf8b9389f1d775.pngimage.thumb.png.66d71c824a9fa418121439f0457571ea.png
    Actually printing through this has proven quite difficult. I now get a 200 response code but nothing occurs on the printer...
          • Heart
        • 4 replies
