The gcode (as per cura preview) does not show any issues.
I have done a bunch more testing and I need to follow up on two items - I have a considerable amount of play between the bowden tube and the bowden coupler with the tube sliding in and out during retraction moves and I also need to re-calibrate the pressure advance setting. I will run another test print after this is done and post a follow-up tomorrow.
burtoogle 514
Could you please attach some sample gcode that exhibits this issue. Thanks.
