List of all G-Code Commands Cura (Marlin Flavor) will use when slicing?
Posted
· List of all G-Code Commands Cura (Marlin Flavor) will use when slicing?
STL files contain only triangles. No curves. So when a slicer slices a layer it finds the intersection of a plane with these triangles and ends up with a lot of lines. No curves. So cura creates no curves. No splines. So good news for you I guess.
I have completely rewritten the path planner for redeem (open source motion controller - runs on beagle bone black) so I'm very familiar with these. I've also looked at repetier host (open source - arduino hardware) and Marlin (open source - also arduino). I'm familiar with all these controllers.
One key thing is understanding the concept of what ALL of these path planners call "jerk" but is not jerk. It's "maximum instantaneous change in magnitude of motion". It's in mm/sec (or meters/sec in redeem). This sets the max junction speed. So for example if you are making tiny angle changes while printing a circle you can pass through the junctions (point at the end of each G0 or G1) at a high speed - maybe 100mm/sec. But if there is a 90 degree corner you have to slow down to 14mm/sec at the junction (assuming jerk is 20mm/sec). This is because if the head is moving 14mm in and out of the junction the change is the hypotenous or sqrt(14^2+14^2)=20
Another key concept is the "backwards planner". The arduino can only plan about 16 moves ahead (beagle bone black can do about 256 moves ahead). So you have to be able to stop. If you were moving at 300mm/sec on the final move which is say only 1mm long and then you stop, you will have a problem (skipped steps). So instead the planner makes sure you can always stop with the known next 16 steps (or so - depends how many steps are loaded into the planner at any given moment).
Posted
Thanks for the information! Also the clarification on jerk because I always assumed it was the mathematical definition of jerk and had no idea it was something entirely different! That also makes sense that its only linear commands because of your explanation of triangles which I definitely overlooked. This is all very intriguing info regarding the planner which I will definitely have to do more research into. Again, thanks for the knowledgeable info and insights.
gr5 2,071
Let me know if you have any questions.
tcoons 0
