I'm pretty happy with (PrimaSelect PVA+)
Proes:
it's fairly easy to dissolve in water, even cold water (room temperature).
and its not so sensitive to ambient moist as some other brands.
Does not string "relatively"
reasonable layer bonding at low print tempters.
Cons:
Expensive compared to other pva brands.
can get fragile/porous over time.
"Don't think it will make a difference. But I only use the 2.85mm variant."
DirgDiggler 19
I use PolyDissolve from Polymaker in combination with the Polybox (Drybox) from Polymaker. In my opinion the support dissolve faster in water and it has a better "look" than the PVA from Ultimaker. But thats the only brands i used so far.
But most of the time i use Breakaway from Ultimaker as the support material. It is easy to print and remove. But i dont know if their is anything like this with 1.75mm
