I have the s5 with the material station and I keep my feeder tension at half way and print an aray of material. I have had a small chunk of filament break off during material change and lodge in the feeder, I had to pull the cover off and remove it. If your feeder is too tight, which I have done, that will cause problems as well. I also had an issue with the material station where the filament wouldnt reach the nozzle and that turned out to be a bad bowden tube. You may want to clean your nozzle as well, cleaning filament works great for that.
The material station is pretty slick I will say.
Framar 39
It's surely not normal. Was the nozzle clogged? Most of the time I had feeder problem it was caused by a partially or totally clogged nozzle...
