Should I still do that if this has already been reported? I'm pretty sure it has been a bunch of times. Is there any workaround or should I just keep using 3.2.1? 4.4.1 was working before I reinstalled it, so it seems like it should be possible to get it working again...
On 1/19/2020 at 6:29 AM, formVfunction said:Should I still do that if this has already been reported? I'm pretty sure it has been a bunch of times. Is there any workaround or should I just keep using 3.2.1? 4.4.1 was working before I reinstalled it, so it seems like it should be possible to get it working again...
If it's reported already, it does help if you post how you got your issue (full logs, specs, etc) in that issue as a comment. It gives us more info to work with and also increases the priority (since more people seem to suffer from the issue)
nallath 1,117
Please report Cura issues at https://github.com/Ultimaker/Cura/issues/new/choose
