"Second, is there a setting so that the outline walls are built OUTWARDS instead of INWARDS? I essentially end up with a hollow print where the inside is actually smaller than it's supposed to be, since the slicer set up the walls to go towards the inside. I'd like to have the walls built outwards such that innermost wall should be the correct same size as my model, if any of that makes sense."
I'm also looking for the answer to your second question - wondering if you managed to figure this out?
Thanks
geert_2 557
I think you would best use the "shelling" commands in a CAD program. Or delete the top- or bottom surface in CAD, so you end up with a non-solid surface-only model, which has zero wall-thickness and is unprintable at that moment. And then thicken that surface *outwards* until it is 2x nozzle width, so it becomes a printable solid again.
And then design some supports, so that the print can stand upwards or upside down, whatever is required for casting, without toppling over. And if required: add pouring canals, venting canals, cut the mould in two halves, make flanges at the seams, provide alignment features, clamping features (e.g. holes for screws or clamps), etc... It all depends on the model, how many undercuts it has, and how flexible the casts are going to be.
I would suggest you watch Youtube videos on "mould making and casting". These mostly apply to old-style silicone and gypsum mould making, and casting resins. But a lot of the basic concepts and techniques can also be used in 3D-CAD-designed moulds. I learned a lot from these.
