Bonding multimaterials
thorsenrune
Posted · Bonding multimaterials
Hi, with our UM5 I work on composite models being partially tough pla partially rubber TPU95.
I try to figure out what is the most efficent and strongest method to make the PLA area bond with TPU area on the same print. Anybody having experiences?
    Also try using mechanically interlocking features. Since this is highly recommended for injection moulding in overmoulding, according to the manuals, I think it also applies for 3D-printing. At least, it shouldn't hurt.
    Think of a dovetail system, or hooks, or chains that interlock. Think of these concepts, but then all melted and squeezed into one solid block.
    Have a look at how it is done in tooth brushes: most of them also have overmoulding with interlocking features.
    I did some tests and this is what I found:
    Testpiece
    https://cad.onshape.com/documents/d2d908babdc85d50637f9646/w/52297ecc71401cbb8aa29987/e/809910c19b9456f702a47d12
    jCi1HJlvy_GMDaW8XEOW8uu3GQyt3AhxBKYNHJleHnC2x10yjKh-0-WTk4KUcyMRDby_6yaX1b-nA6437_y1y6mwudPzdJwUSMYqe5W2c5sd697pHugRC9y2EIBaQYvy2HrPiS_gYSKCghTNkX2C3GufI0HiHeSeSHE6fttY6HEXrPI-T44ZFbVOqs8ewFfy8xizaIcD4SmoeEF9_kVaC-6nPOetiAyYm2wUwAvF9QjNUG9gwhhR5JFiXox9XhJSRntyvfe4jkwHuWay
    Center is TPU and the frame is TOUGH
    The test is to see if some anchoring will improve adhesion
    Conclusion.
    Use overlap between different materials and let the slicer do the stitching job.
    Experiment 3
    Half overlap and stitching results in a strong interface between TPU and PLA
    Z5xzhsziqJ-o2oIbDmTYpLf6x-6fxX-7I5kveVqm8c3H8q4u9xA5XG2NIuMPNZEC0g8h45f0oY97d-PIYwBrWfEZwyFzl2MENOMxuVFmDZp_XPVx-Lr_mDxZXzOa9ouZk4V9444r link
    1 Hour print
    3tbAsMF7CmqkWF74lwZ-Dkd17XgWQVFwTId-Po6VZtR02ykU58ooOwDznHrwXTk_gWCM90U2CDCBaoe-O1aaAUm8hXNRbeI2iiPJmcYGHM3NHRUnZTkiQrMVpOgoz4G2M9T7aA6A
