And what did cura do?
Other slicers will let you limit the support structure. Not Cura.
You have many choices - most of them likely bad - hard to say without seeing your model.
One possibility is to add your own support as part of the CAD model.
Thanks for the advice, had not thought about adding my own support structure to be honest. Will give that a go
gr5 1,968
