I changed the flow rate within the tune-menu after started printing.
17 hours ago, tinkergnome said:And out of curiosity: why so much? Is it a special material?
I was basically just playing around with some settings, I have some nylon that seems to have no layer adhesion at all, so I tried some things to work against that.
1
tinkergnome 926
How do you change the flow rate? In the "Tune" menu during a print, in the material settings (on the printer) or somewhere else with a gcode command?
Anyway: the standard firmware does not reset the extrusion multiplier at the end of a print, only at the beginning.
It should be possible to add an explicit gcode to the end-script (somewhere in the slicer settings - depending on the slicer you use).
https://reprap.org/wiki/G-code#M221:_Set_extrude_factor_override_percentage
