It should do retraction before lifting the head...
I'm currently working on dual-extrusion stuff. One of the things is a wipe tower, which is a bit of the same as the trash bin. One of the issues I have with it right now is that it can topple over when your prints get high.
jonnybischof 60
I have an idea that could maybe solve this problem:
Imagine a small diameter cone next to the object being printed (the cone is of course being built up by the printer along with the printed object).
Now if the hotend moves away from the object, it goes behind this cone, and when it goes back to the object, it moves over the cone, stripping any oozed plastic off the hotend. So the hotend arrives at the object cleaned. The cone gets all the excess material, but as it is just a disposable item, it doesn't matter. I don't know how long the wait time is, I've never thested this feature, but why not just go over the cone several times if necessary and "clean" the hotend whenever necessary?
Also, the mere fact that the printer has to do more work per layer will already increase layer time.
Drawbacks:
- You waste some material for printing the cone (best keep it always hollow, ignoring infill settings, and note that oozing is also wasting material...)
- If you have stringing problems, you will have more stringing problems than before
/edit:
You could position the hotend "inside" the hollow cone in order to get all oozing material inside it. Then you could name the feature "trash bin".![:D](//content.invisioncic.com/ultimake/emoticons/5a33abe7dfbbe_1f600copy.png)
