Experiments on Bridging
rich
Posted · Experiments on Bridging
Be aware that if you change XY acceleration using ulticontroller (or pronterface) the change is not saved such that when you power cycle the UM it will go back to defaults. There *is* however a save command to save it permanently (M500 maybe?).
Also acceleration of 800mm/sec/sec is very rapid (I think 5000 or 8000is the default?) and not much different from the default. Whereas an acceleration of say 30mm/sec/sec is quite noticeable and might be more reasonable for bridging tests.
Think about it: at 800mm/sec/sec, within one second the head could be moving 800mm/sec! To get up to 100mm/sec it takes only 1/8 of a second.
        • 56 replies
        • 29 replies
