I have never printed with ABS but I read a lot. Most people heat the bed up. very hot. And they create "ABS glue" by mixing some spare ABS with acetone and letting it dissolve for a few hours. Then paint the "glue" onto the glass bed. Let it "dry" and then print on that. Should stick like you wouldn't believe. You may have trouble getting it off the glass although if you let the glass cool completely, the difference in thermal expansion of the 2 materials will help quite a bit.
You can also paint on blue tape but it will destroy your tape getting the part off. You will need razor blades. You can then soak the bottom of your part in acetone for a few minutes and the tape should slide off.
Most people don't seem to use raft anymore. But I can see how it is nice as it flexes as the part shrinks and still hangs tight.
gr5 1,870
I don't know much about raft at this point, but in advanced settings there is a "gap" you can set in the support material section ("Distancy X/Y (mm)". Set that to zero and compare in Cura "slice view" to see if that helps.
