Im having issues looking for setting in ver 4.4 and 4.41. I wonder if 4.5beta has it?
The setting where 1) I can set to pause ( at certain line number)printing so I may change filiments (color) and 2) I don't have to be there to manually watch and hit pauseprint on my Ender screen
Maybe I should look for Cura 4.1
I found ver 4.1 does this version come PAUSE at (layer #, height, or line count)? I downloaded ver 4.1 but will wait till I hear it does, and am told where in that ver I'll find it
Edited by Bruce19Added text
Check this video on YouTube, in this video is explained how to Pause at height/layer... this option in in Cura for a long long time... Since I have troubles with in in 4.4.0/4.4.1 it is better to use 4.1.0 till they have fixed it!
Edited by Mari
Mari Thank You VERY VERY much. I had downloaded version 4.1, installed it too. Spent about 20 mins looking with no luck until you sent CHEPs video. As I watched I had Cura open making same setting changes. Right now printing "ender 3 pro" starting to print in blue then hopefully it will be waiting for black. IF I did everything correct. THANK YOU
QUESTION I noticed in version 4.4.1 has same modify G code options as 4.1. Is it that after making mods in 4.4.1 it didn't "stick" when printed?
Mari 32
Lucky me... still had 4.1.0 installed on another computer... and yes I can conform that Pause at Height works like it should in that version...
They broke it in 4.2.x, fixed it in 4.3 and broke it again in a later version... Hopefully they get it fixed again!
